How to split a surface as a "lid" or cover?
mubin_icyermubin_icyer Member Posts: 13
edited June 2023 in Drawings
Hi,
I created a model in onshape and want to make a lid. The surface has a shape that I couldn't draw on a sketch to split, because splitting curves are not flat.
How can I split the surface as a lid?
https://cad.onshape.com/documents/8b24f97526fb35d8816153f3/v/c0cd1e9148666582cba568a0/e/78818a1ca37d020e5097b1ba?renderMode=0&uiState=6491c8475d0afc1896909b44
Thanks.
  • EvanReeseEvanReese Member, Mentor Posts: 2,445 ✭✭✭✭✭
    I think you'd have to manually model the surface that represents the separation and use the Split tool. The link is view only, so I can't roll back to see your steps, but you could probably start with an offset of 0mm of the wing top surface to copy it and go from there.
