How to extend model length
https://cad.onshape.com/documents/a56195fb22ec05eab71a2040/w/ff22ba56ef367c18b6cba8a9/e/48bf376c730db276682be915
I've done one mockup of this end cap and I'm trying to figure out how to add 5 mm to the overall length without changing any of the other feature's respective locations. All that I need to do is essentially cut along the dotted line I've drawn in, move the end cap 5 mm out, and then connect everything between the cut edges.
Is there a single or set of functions to do this? Or does this require redoing the entire shape from square 1?
Thanks!
Thanks!
