pest practice mating a large number of parts in a assembly
john_denverjohn_denver Member Posts: 5
hi together,
I would be interested to know what is the best practice for rigidly connecting a large number
of similar parts in an assembly, e.g. the iron sheets in the stator of an electric motor.
The first layer (4 sheets belonging together) is to be attached to a sketch
and then the idea is to copy&paste this layer again and again to create the stack.
What exactly should be mated with what?
BR
John
  • wout_theelen541wout_theelen541 Member, csevp Posts: 198 PRO
    For the iron sheets it sounds like you would want to use replicate, Composite parts might also be an interesting option thought I haven't used it before:
    https://forum.onshape.com/discussion/comment/92861#Comment_92861
    I would avoid copying and pasting though it might be doable for a limited number of parts with group mates but I prefer using subassemblies or one of other 2 tools mentioned above.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    If they are all the same part, use assembly linear pattern.
  • S1monS1mon Member Posts: 3,872 PRO
    Another thing to consider - are you designing the motor, or just representing an off the shelf motor for a larger project? If the latter, perhaps representing the stack as a single part is easier.
  • john_denverjohn_denver Member Posts: 5
    I design the motor itself.
