How to mirror an object without copying it?
blackslate
blackslate Member Posts: 18 ✭
I want to move an object into its position in a mirror defined by an arbitrary plane. I do not want to create a copy.
Below is how I can achieve this using opPattern, and then deleting the original. Is there a more elegant way?
On this page, from 2017, Jake_Rosenfeld suggested to try something like this...
mirror(context, id + "mirror1", {
        "patternType" : MirrorType.PART,
        "entities" : someQueryForEntities,
        "mirrorPlane" : someQueryForTheMirrorPlane
... but this is no shorter* and also creates a copy, as you can see here.
(*Perhaps it is more efficient?)
You can see my working (but inelegant) version in action here.
FeatureScript 2066;
import(path : "onshape/std/common.fs", version : "2066.0");
annotation { "Feature Type Name" : "Mirror Test" }
export const mirrorTest = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        const goldenRatio = (1 + sqrt(5)) / 2;
        const goldenCorner = vector(1, goldenRatio) * inch;
        // Draw some construction lines
        const sketch1 = newSketch(context, id + "sketch1", {
                "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
        skRectangle(sketch1, "rectangle1", {
                "firstCorner" : vector(0, 0) * inch,
                "secondCorner" : goldenCorner,
                "construction": true
        skLineSegment(sketch1, "line1", {
                "start" : vector(0, 0) * inch,
                "end" : goldenCorner,
        // Create a rectangle to extrude
        skRectangle(sketch1, "rectangle2", {
                "firstCorner" : vector(1, 0) * inch,
                "secondCorner" : vector(1.1, goldenRatio) * inch
        skSolve(sketch1);
        // Create a mirror transform
        const x = normalize(vector(1, goldenRatio, 0));
        const normal = cross(x, Z_DIRECTION);
        const mirrorPlane = plane(WORLD_ORIGIN, normal, x);
        const mirrorTransform = mirrorAcross(mirrorPlane);
        debug(context, mirrorPlane, DebugColor.RED);
        // Extrude a shape
        opExtrude(context, id + "extrude1", {
                "entities" : qSketchRegion(id + "sketch1"),
                "direction" : Z_DIRECTION,
                "endBound" : BoundingType.BLIND,
                "endDepth" : 1 * inch
        // Mirror it
        opPattern(context, id + "pattern1", {
                "entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
                "transforms" : [mirrorTransform],
                "instanceNames" : ["mirror"]
        // Delete the original
        opDeleteBodies(context, id + "deleteBodies1", {
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    edited June 2023 Answer ✓
    Try something like this:
    https://cad.onshape.com/documents/afedfd6fe11ea21e5eec3375/w/72b...
    annotation { "Feature Type Name" : "Mirror transform" }
    export const mirrorTransform = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Entities", "Filter" : EntityType.BODY }
            definition.entities is Query;
            annotation { "Name" : "Mirror plane", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
            definition.plane is Query;
            const mirrorPlane = evFaceTangentPlane(context, {
                    "face" : definition.plane,
                    "parameter" : vector(0.5, 0.5)
            opTransform(context, id + "transform1", {
                    "bodies" : definition.entities,
                    "transform" : mirrorAcross(mirrorPlane)
    RENDERCAD
  • MichaelPascoe
        precondition
    RENDERCAD
