How do I do a removal extrude on the curved side of a loft?
travis_grenelltravis_grenell Member Posts: 11
I need to extrude a hole on the curved side of a loft, but it won't let me select that edge of the loft. What do I do? I've tried drawing it in thin on a plane air but then it won't let me do a removal extrusion.
In a related problem, I need to make the hole I'm extruding be perpendicular to the part, not the loft edge. How do I do that?
  • glen_dewsburyglen_dewsbury Member Posts: 1,257 PRO
    Can you post a link to the document.
    It would help to see what you're saying.
    edited June 2023
    @travis_grenell
    One way is by using — Surface Tangent Plane
    The first GIF, which is the one directly below, shows you how to set up a TANGENT plane which is the first step
    Once you make a tangent plane as shown above, then you can use that plane to make a sketch in order to place a point on that plane, because what looks like a point on the plane when the plane is created, will not act as a point for creating a hole
    So you place a point on the plane, and make it coincident with the center of the plane
    Now you can use the hole tool on that point, as shown below
    edited June 2023
    Here is the Surface Tangent Plane featurescript
    https://cad.onshape.com/documents/0de04acb5bac92ca16796edf/v/685026de2603b19fd2c6003d/e/680f0565e919e6e39a06f4df
    And here is how to install a featurescript
