Pattern Development
chester_softleychester_softley Member Posts: 2 EDU
I am trying to make a template for a pipe support - Pattern development i have drawn it as a flat pattern but i want to dimension it so that i can transfer it onto physical sheet metal looking to get the following measurements = drawn them on roughly i want want them in increments of 10mm apart from left to right is this doable in onshape?
  • S1monS1mon Member Posts: 3,989 PRO
    At that scale, it seems like you could easily fit that on a print (you might need to split it into a few pieces depending on the max size of paper your printer can manage). Why not create a drawing and use that as your template?
