Countersunk Holes
stephen_sherwood846
Member Posts: 26 ✭✭
Is there a custom featurescript to do multiple countersunk holes (like you get in fusion 360)? I know I can draw holes on the sketch and then chamfer them but when you have a lot of holes it's a bit tedious.
If not, then it is definitely a core onshape feature I would like to see.
Just select the Hole feature with "Countersink"option and select your whole locations from a sketch or mate connectors.
Is that what you are looking for?
Cheers,
David
