Lofting
doug_hillsdoug_hills Member Posts: 29
Hi everyone,
I've never done a loft before, and I'm having a hard time with this one, likely way to complex for a beginner, but its what I need. Unless ther is a better way to join the upper and lower sections.
The upper is wider than the lower, and will need to be hollow, with a .062 wall thickness.
Sketches 8,9,10 are the crossections, and seketch 11 is the shape I want (I was trying to create a path). It will have a fillet to join with the upper nipple..
https://cad.onshape.com/documents/e80b1b3ae08927502d18d581/w/9fd1adb5c3713b133ac38315/e/2381988d43d2e21c01f8e9c7
Thanks for your help.
  • glen_dewsburyglen_dewsbury Member Posts: 1,304 PRO
    @doug
    Lofting can be a bit tricky. When you use guide curves they want to be at pierce points with profile curves.
    Here's some ideas that might help.
    https://cad.onshape.com/documents/f72c7797b0e05baebf133137/w/e8cbe8e0bb87b85ab5e93461/e/bfd754f9cbbb366ca915f7fc
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,605 PRO
    Lofts don't handle "hollow" profiles, so you need to loft it as a solid and then hollow it out using shell (or a second loft with the remove option). You also had other issues
    - The profiles not being in the right order
    - The guides not actually piercing all the profiles
    - The guides "fighting" the end conditions (guide perpendicular to profile at the top but end condition normal to profile)
    - Lastly the transition is just too steep, I improved a bit by moving the mid profile down but it's still not great, removing it altogether might be a better option.
    Something like this;
    https://cad.onshape.com/documents/c2dfdcbc013272be7c6dd505/w/aecc512efbdb39544fd029e9/e/52b5040581caafb1c5f9d338
  • ian_bottomley909ian_bottomley909 Member Posts: 10
    Hi Doug
    From one beginner to another - I had a battle with lofting too. I suspect you are asking too much of the lofting algorithm trying to solve the whole, 'three pipe into one' question in one go. I have had more success working in stages.
    1). Make a solid loft that is the outer shell of the require part.
    2),3), & 4). make individual cores that represent each flow path from one of the manifold pipes to the main pipe
    subtract 2,3,4  from 1 in a sequence of Boolean operations...
    And hey presto ...
    Maybe ...
    Ian B.
