Deleting part studio/assembly/drawing can have unpredictable navigation problems
Michael_UrsuliakMichael_Ursuliak Member Posts: 14
I often like to sort my onshape tabs into folders for ease of navigation.
I might have something as follows:
Main(assembly),
Parts->
    SheetMetal,
    BackPanel ,
    Frame->
        Base
        Lifting Hook
But if i decide that i want to delete some tabs for example Lifting Hook and Base;
If i am in those tabs when i delete them, my nav bar gets tossed to a seemingly random file that isn't always even in the same folder.
I then have to navigate all the way back to the folder to delete the next file, and get tossed again.
It would be nice if i could just stay in the folder that i am working in.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,590 PRO
    Use the tab manager when working on documents with more than a few tabs! Much easier to keep track of where you are in the document structure (and you can select multiple tabs to delete at once).
