Primitive sphere creation from points
Dean_Gardner
Dean_Gardner Member Posts: 114 PRO
Does anyone know of a feature script that can create a 3D sphere from 3 or more points?
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    FeatureScript 2075;
    import(path : "onshape/std/common.fs", version : "2075.0");
    annotation { "Feature Type Name" : "Sphere 3 Point" }
    export const sphereThreePoint = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
             annotation { "Name" : "Points", "Filter" : QueryFilterCompound.ALLOWS_VERTEX, "MaxNumberOfPicks" : 3 }
             definition.points is Query;
            var pts = [undefined,undefined,undefined];
            for(var n=0;n<3;n+=1)
                pts[n] =evVertexPoint(context, {
                        "vertex" : qNthElement(definition.points, n)
           var cir =getCircleFromPoints(pts[0],pts[1],pts[2]);
           opSphere(context, id, {
                   "radius" : cir.radius,
                   "center" : cir.coordSystem.origin
    function getCircleFromPoints(a is Vector, b is Vector, c is Vector)
        try silent
            var Xa = a[0] / millimeter;
            var Ya = a[1] / millimeter;
            var Za = a[2] / millimeter;
            var Xb = b[0] / millimeter;
            var Yb = b[1] / millimeter;
            var Zb = b[2] / millimeter;
            var Xc = c[0] / millimeter;
            var Yc = c[1] / millimeter;
            var Zc = c[2] / millimeter;
            // Lengths of AB, AC, AC
            var AB = (((Xa - Xb) ^ 2) + ((Ya - Yb) ^ 2) + ((Za - Zb) ^ 2)) ^ 0.5;
            var BC = (((Xb - Xc) ^ 2) + ((Yb - Yc) ^ 2) + ((Zb - Zc) ^ 2)) ^ 0.5;
            var AC = (((Xa - Xc) ^ 2) + ((Ya - Yc) ^ 2) + ((Za - Zc) ^ 2)) ^ 0.5;
            //Direction cosines of AB(ABi,ABj,ABk)
            var ABi = (Xb - Xa) / AB;
            var ABj = (Yb - Ya) / AB;
            var ABk = (Zb - Za) / AB;
            //'   Direction cosines of AC(ACi,ACj,ACk)
            //var ACi = (Xc - Xa) / AC;
            //var ACj = (Yc - Ya) / AC;
            //var ACk = (Zc - Za) / AC;
            //'   Cosine of angle BAC
            var cosBAC = (AB ^ 2 + AC ^ 2 - BC ^ 2) / (2 * AB * AC);
            var AD = cosBAC * AC;
            var CD = (AC ^ 2 - AD ^ 2) ^ 0.5;
            //'   Position of point D, which is C projected normally onto AB
            var Xd = Xa + (AD * ABi);
            var Yd = Ya + (AD * ABj);
            var Zd = Za + (AD * ABk);
            //'   Direction cosines of CD(Cdi,CDj,CDk)
            var CDi = (Xc - Xd) / CD;
            var CDj = (Yc - Yd) / CD;
            var CDk = (Zc - Zd) / CD;
            //'   Direction cosines of normal to AB and CD
            //'   — to be used for rotations of circle centre
            var Ni = (ABk * CDj) - (ABj * CDk);
            var Nj = (ABi * CDk) - (ABk * CDi);
            var Nk = (ABj * CDi) - (ABi * CDj);
            //'   # Diameter of circumscribed circle of a triangle is equal to the
            //'   the length of any side divided by sine of the opposite angle.
            //'   This is done in a coordinate system where X is colinear with AB, Y is // to CD,
            //'   and Z is the normal (N) to X and Y, and the origin is point A
            //'         R = D / 2
            var sinBAC = (1 - cosBAC ^ 2) ^ 0.5;
            var R = (BC / sinBAC) / 2;
            //'   Centre of circumscribed circle is point E
            var X2e = AB / 2;
            var Y2e = (R ^ 2 - X2e ^ 2) ^ 0.5;
            var Z2e = 0;
            //'   Transform matrix
            //'                    Rotations                 Translations
            //'               ABi  ,   ABj  ,  ABk                 Xa
            //'               CDi  ,   CDj  ,  CDk                 Ya
            //'                Ni  ,    Nj  ,   Nk                 Za
            //'   Position of circle centre in absolute axis system
            var X_centre = Xa + (X2e * ABi) + (Y2e * CDi) + (Z2e * Ni);
            var Y_centre = Ya + (X2e * ABj) + (Y2e * CDj) + (Z2e * Nj);
            var Z_centre = Za + (X2e * ABk) + (Y2e * CDk) + (Z2e * Nk);
            var circleCenter = vector(X_centre * millimeter, Y_centre * millimeter, Z_centre * millimeter);
            var radius = pointDistance(circleCenter, a);
            var plane = try(planeFrom3Points(a, b, c));
            if (plane != undefined)
                plane.origin = circleCenter;
                var coordsys = coordSystem(plane);
                return circle(coordsys, radius);
        return undefined;
    export function pointDistance(vec0 is Vector, vec1 is Vector) returns ValueWithUnits
        var vec = [vec0[0].value - vec1[0].value, vec0[1].value - vec1[1].value, vec0[2].value - vec1[2].value]; //makeArray(size(vec0), undefined);
        return   sqrt(vec[0]*vec[0] + vec[1] *vec[1] + vec[2] *vec[2]) * meter;
    export function planeFrom3Points(pt0 is Vector, pt1 is Vector, pt2 is Vector)
        var points = [pt0, pt1, pt2];
        var normal = cross(points[2] - points[0], points[1] - points[0]);
        try silent
            //check if the 3 points are on a line;
            var vec1 = points[0] - points[1];
            var vec2 = points[2] - points[1];
            if (parallelVectors(normalize(vec1), normalize(vec2)))
                return undefined;
        try silent
            var ret = plane(points[0], normalize(normal), normalize(points[1] - points[0]));
            return ret;
        return undefined;
    This will do it.
  • eric_pesty
    edited July 2023
    Sorry it doesn't look like I actually read what you said... Coffee hadn't kicked in yet apparently!
    Is this what you are looking for?
    https://cad.onshape.com/documents/a81f647d405a78c5b70bdbde/v/b1e90d8c768f69db42c07f9a/e/bec98f91580bad4c70005038
    Or do mean getting passed a bunch coordinates?
    Maybe using one of the "3D points" features first and then this should work (haven't tried thought)...
    Also Polyheadron:
    https://cad.onshape.com/documents/2c40f522f1b5a02f6ce9ce01/w/32e0799ad10a8f40ac24abb5/e/dd23a5b64fbc7cefbf67ffbd?renderMode=0&uiState=64b58578f6ee8b108a11e366
  • _anton
    _anton Member, Onshape Employees Posts: 554 image
    I believe you need more than 3 points to define a sphere. Also, what if they don't lie on the surface of any possible sphere or you have more points than needed? Are you looking for a bounding-sphere sort of solution?
  • Jacob_Corder
    FeatureScript 2075;
        precondition
        try silent
            //'         R = D / 2
            var X2e = AB / 2;
            var Z2e = 0;
            //'                Ni  ,    Nj  ,   Nk                 Za
        return undefined;
        try silent
                return undefined;
        try silent
            return ret;
        return undefined;
    This will do it.
