What else should I include on this drawing?
michael_moore728
Member Posts: 3 ✭
in Drawings
I've completed my model and am putting together a drawing. I come from maya/polygon modeling, so these drawings are new to me.
What should I include (or remove) on this drawing before I send to a customer? They need the drawing to get a quote from a manufacturer.
1) Make sure your title block is filled with all the details.
2) Please verify the precision value for every dimension, confirm what tolerance range it is required to manufacture.
3) Arrange all the dimensions in proper manner so that drawing looks good.
4) You need to mention sheet thickness in one of the view.
5) Angle need to be mentioned in right side view.
6) Show the profile details for lower cross-section of loft feature
7) If it is supposed to be in sheet metal you need to provide bend radius somewhere
2) Does the sheet metal base have a hole in it corresponding to the base of the cone?
3) if the cone is sheet metal are all the faces solid or are some removed?
4) Either way the cone and base needs making in two parts (not enough metal to form from one piece) how are they attached and where?
5) As two parts in manufacture (base plate and cone) easiest to give two drawings possibly for this and then one showing how and where to attach them, probably either spot weld, mig/tig weld or glue.
Note you can add notes to drawings to fill in title block and give general tolerance dimensions. Also if model is translucent you can show internal lines on drawing (when holllow etc)
Otherwise there is a risk that the manufacturer will go back to your client and tell them bad things about you.
Your dimensions from the edge of the bottom plate to the outer profile of the protrusion are probably not as helpful as dimensioning the protrusion in both directions, then giving (say) 6.1" to the steep end. In the other direction, show the centerline of the protrusion lying on the centerline of the baseplate (by running a chain dashed line right through the view), and together with the 3" width of the protrusion, this tells the whole story.
If the item is made from two separate pieces, you need to show a typical section through the join, showing how is it is to be made and bonded.
