Thread creator won't do 1.6mm diameter 0.35mm pitch with ISO Standard
lorenz_michels
Member Posts: 4 EDU
Hi,
I tried Tread creator for the first time. When trying to make a hole for a metric M1.6 and pitch of 0.35, Onshape Fails. When trying the same for an M1 everything works fine.
What am I doing wrong? Is this a bug?
Kind regards,
Lorenz
Kind regards,
Lorenz
I had six holes created by a circular pattern in the sketch and these subtracted from the part i was working on. The origin of the circular pattern worked immediatly with this thread. With all the five 'copies' I had to flip the orientation of the thread and it worked fine as well.
Completely happy with the Thread Creator (TH).
PS: Jacob_Corder, thanks for your reaction!
