Is there an easy approach to copy and paste this text to another plane so it is on both sides?
carlos_berdealcarlos_berdeal Member Posts: 76 ✭✭
I would like to put this text I created on one plane on the other side on plane 13. Is there an easy approach to this?
  • S1monS1mon Member Posts: 3,768 PRO
    You could extrude the text and not intersect it, then do a transform/rotate (copy). Then you can do a boolean after.
    You should consider cleaning up the sketch for the logo. It's ok for a 3D print, but if that's going to be injection molded, it's got a lot of issues.
