Can't Solve Sketch when switching Configurations. Configurations break sketch
lukas_sturm148lukas_sturm148 Member Posts: 6 EDU
Hi there, not sure if this is a bug, but I need a workaround
I already used the report a bug feature, but I don't know it that worked (I received no email or any information that the report was sent)
I have a sketch that is solved, if I switch configurations and come back to the same configuration it is over constraint.
I then have to remove some constraints, until it is under constraint, then move everything back to together roughly.
Then I add the same constraints back I just deleted, but this time it is solved properly.
I am still very much a beginner, so this could also be a misunderstanding on my part.
Here is a Link:
https://cad.onshape.com/documents/c301e4176ea67ac1ebb46191/w/444c2345fe9c68e698e2cf12/e/6ade3c297d79ca1233d844cf?configuration=Left_Holes%3Dtrue%3BList_tlfVwZDHQyUMU0%3DDefault%3BRight_Holes%3Dtrue%3BZip_Tie_Groves%3Dtrue&renderMode=0&uiState=64cc7ada6279f015048d0f21
Bottom-Opening-Sketch and Right-Opening-Sketch have the problem. (I think I once also saw it on Left-Opening-Sketch too)
  • glen_dewsburyglen_dewsbury Member Posts: 1,296 PRO
    There are other things that fail as well when changing config check boxes, but difficult to analyze with out copy access.
    The shared link is view only. Can you make public?
    I can see what features fail but can't edit feature to see the detail of what's failing.
  • lukas_sturm148lukas_sturm148 Member Posts: 6 EDU
    I clicked "make public"
    I also changed my mind on how I want this "function" do be implemented in the part. I created a new branch with my new idea.
    But feel free to take a deeper look, I am very interested in some feedback.
    It seems you eliminated the sketch fail in the new branch (B1). The problem still in main is a projected entity that was applied in panel 2, but could not resolve in the other configurations. When the mates of the projected line are removed the error goes away but so does the position of the whole sketch. Something in the right and left opening sketches has changed to make this happen.
