Spline with an array
hervé_pipon
hervé_pipon Member Posts: 60 ✭✭
Hello
I need some help with the spline.
I wrote a feature which draw a spline from a csv file
Inside I use this code
} else if (linetype == "C") {
            var P1 = point_courant;
            var P2 = vector(aline[1], -aline[2]) * ZoomCoefficient + splineOffset;
            var P3 = vector(aline[3], -aline[4]) * ZoomCoefficient + splineOffset;
            var P4 = vector(aline[5], -aline[6]) * ZoomCoefficient + splineOffset;
            var start = P1;
            var end = P4;
			var startDerivative = 3 * (P2 - P1);
            var endDerivative = 3 * (P4 - P3);
            skFitSpline(sketch1, "spline_"~ entityCount*100, {
                "points": [
                    start,
                    end
                "startDerivative": startDerivative,
                "endDerivative": endDerivative,
            point_courant = P4;
Unfortunately the display is not the same as with the spline tool
There is lots of "glued splines" but not a single smooth curve
-- In green a spline created with the spline tool : separation are shown only when curve is a line.
-- In blue the one from my featureScript  :( : separation are shown for each points of the spline
I changed my way to draw all the connected point at once with this code
1/ first detect the end of point list to draw all at once
if ((lastlinetype == "C") && (linetype != "C")) {
            if (splineopened) {
                print("spline_"~ entityCount);
                print(" = ");
                skFitSpline(sketch1, "spline_"~ entityCount , {
                    "points": splinePoints,
                println(splinePoints);
                splinePoints = [];
                splineopened = false;
2/ and instead of drawing the curve, I memorize the points in a list
            var start = P1;
            var end = P4;
            splinePoints = append(splinePoints, start);
            splinePoints = append(splinePoints, end);
            if(splineopened == false) {
            splineopened = true;
            point_courant = P4;
But it does not work!!!
And I don't understand what is wrong
Can you help ?
