Bend part
Hi,
I have a very simple rectangular part, a few cm in length and a few mm thick. I wish to bend the whole part to a radius of c. 200mm.
ie, the part is pressed out of sheet steel, then bent to form a very slight curve.
How do i do this in OnShape?
NB. I do not want to built it on a curved extrusion path, or use plane intersects to 'cut' it from a larger pieces. I want to BEND this piece.
1
Twitter: @BryanLAGdesign
