Why debug feature is not displayed ?
hervé_pipon
Member Posts: 60 ✭✭
Hello,
When I use the debug feature on a vector, the data are displayed in the FeatureScript Notice, but the lines are not drawn on the screen.
I thought they should appear, right?
https://cad.onshape.com/documents/b779fbc5c77223353d4ce6aa/w/5beeb6a22fc35205de002ae9/e/8b9603a52ac1124f31a8ba58
I use the debug feature to display these lines on the sketch
// 1st line
var line1Start = [x1, y1];
var line1End = [x2, y2];
debug(context,vector(line1Start, line1End), DebugColor.RED);
// 2nd line
var line2Start = [x3, y3];
var line2End = [x4, y4];
debug(context,vector(line2Start, line2End), DebugColor.BLUE);
debug: Vector Vector : [ [ 0.15 , 0.05 ] , [ 0.1 , 0 ] ] debug: Vector Vector : [ [ 0.1 , 0 ] , [ 0.1 , 0.05 ] ]
That is because a vector is just a direction. in your case its just wrong, because its a multidimension array.
you need this
addDebugLine(context, line2Start,line2End,DebugColor.BLUE);0
you need this
addDebugLine(context, line2Start,line2End,DebugColor.BLUE);0 -
@Jacob_Corder Thanks for your suggestion; with your help I made it work with
var line1Start = vector(x1, y1,0) * meter; var line1End = vector(x2, y2,0) * meter; addDebugLine(context,line1Start,line1End,DebugColor.RED);
