Changing a reference model in a drawing
patrick_sheapatrick_shea Member Posts: 63 ✭✭
With Solidworks we used to be able to create a drawing from a 'Reference Model' , give it a new name, then bring in the 'New Model', which was similar to the reference.  The Drawing would update, so you did not have to redraw.  It wasn't always perfect, but it  usually did save time.  Can we do something similar in Onshape?
Patrick
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,475 PRO
    You can do a "replace" on the drawing reference. All the views that use that reference will update. Dimensions and references will break but can be re-attached...
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 566 image
    If you replace from the Sort by sheets view of the panel, then the replace will work just on that particular parent/child set of views and leave the rest.  If you replace from the Sort by references view of the panel, then replace will globally replace all references for the entire drawing with the one you select.
