Can I (or someone who i shared the publication with) download an entire folder as zip file?
For example I grouped the sheet metal parts of a machine by thickness. The subcontractor wants to download every part with the same thickness at once.
Thank you!
  • eric_pestyeric_pesty Member Posts: 2,191 PRO
    I don't think you can download the folder directly but you should be able to select all the items within a folder and export at once (provided they are all the same type).
  • kristof_onghenakristof_onghena Member Posts: 18 PRO
    Thank you for your answer. However in my publication are mainly dxf files ready to be laser cut by a subcontractor. He just needs to download them but this (hopefully i am wrong) has to be done one by one...
