need help
riley_chiselkoriley_chiselko Member Posts: 2
i used line sketch to make the shape of a bicycle frame and i cant figure out how to connect line sketches into one solid sketch i need line sketches to be one big solid sketch how to i turn connected line sketches into on big sketch so i can extrude it as a solid
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 415
    You coud use the Use tool.  Open a new sketch and just Use all of the elements from the previous sketches.
  • nick_papageorge073nick_papageorge073 Member, csevp Posts: 823 PRO
    Are each of those lines in a separate sketch from sketch 1 through sketch 7? If so, start over and make them all in one sketch.
