A flywheel with a diameter of 230mm shrinks to 2.45mm when exported as dxf file
ProApeProApe Member Posts: 231 ✭✭
Hello,
I have drawn the linked flywheel with a diameter of 230mm in 3d, converted it to a 2d drawing with the aim of milling it, and exported the drawing as dxf to do so.
When I open this dxf in Estlcam, the program I use to create the GCode, it has a diameter of 2.45mm!
2 questions:
* what am I doing wrong? Is that the right way to export for milling?
* can I generate the GCode directly in Onshape?
With kind regards
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    https://cad.onshape.com/documents/30e89e5025bf05569598a978/w/4dfc12508c05068f192ea57f/e/6bb52146b00c9a8408fc7d57
    This is a copy of your document, look for sketch 8 and right-click export dxf.
    You could have done this part with 1 sketch in the beginning and build the part with several extrude's
  • ProApeProApe Member Posts: 231 ✭✭
    There is no sketch 8!
    I have followed a tutorial where the author created the object with as many sketches!
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,058 PRO
    There is a sketch 8 in Dirk's copy of your model, not in your original model.
    There are many ways to get to the same end geometric shape. The tutorial you followed was not created in a very efficient way, but in the end, it got the desired shape.
    edited September 2023
    A few questions/comments:
    The shape of your model is a 2.5D (CNC terms) shape, or 3D (CAD terms shape). A shape like that is typically exported as a solid model STEP file from the cad program into the CAM program. Why are you using dxf, which is a 2D export? 2D export such as dxf is typically used for laser cutting and waterjet. CNC such as a milling machine or a CNC router almost always uses a 3D STEP file.
    Next, if your CAM program really does want a 2d dxf, then you must make sure it's full scale. If you export it from a drawing (meant for paper printing), you must do a few things. First, delete all the drawing border/title block/rev block/dimensions/centerlines, etc. There should be nothing on the sheet except the lines of your part. Next, make sure the drawing is set to 1:1 scale. You currently have it as 1:4 scale. Next, dxf is a dimensionless format. When you go from program to program, the second program does not know if the first program was in mm, cm, inches, etc. You must tell the second program what the units are.
    If you want to avoid all that, you can do what Dirk did in his sketch 8 of your model, and export the dxf from the 3d model, rather than the 2d paper drawing. (although the units will still have to be set in the second program).
    For the second question, no, you can't create g-code natively in onshape today. CAM is in the pipeline for later this year.
