Cant get my loft along a guide
heiko_augustinheiko_augustin Member Posts: 9
Hello,
i am trying to get the 2 cone profiles to loft along that edge, but i cant get it to work.
What am i missing out, who can help?
Thank you!
  • robert_scott_jr_robert_scott_jr_ Member Posts: 754 ✭✭✭
    Please post a link to your document.
  • heiko_augustinheiko_augustin Member Posts: 9
    Oh sorry.
    Too sad, i was confused by the forum, had Discussions, Questions, and non of them showing up. I was sure to put in a link everywhere, but obviously i did not.
    Here:
    https://cad.onshape.com/documents/86c451d68fcdf251825af89a/w/90cb2c46423d94b8ba86d73c/e/a846fb1e04a2e68cafbed461?renderMode=0&uiState=64f1e89865d84424b92a0c45
    And thanks!
  • glen_dewsburyglen_dewsbury Member Posts: 1,288 PRO
    edited September 2023
    Here is an example. Loft with guides. It will show errors while you are selecting guide curves because the guide is incomplete. Keep going.
    Also, if the profiles at each end are intended to be the same? Then it's simpler to use a sweep.
    https://cad.onshape.com/documents/5f6784eb8e627bd2935ff8c4/w/d6abc552e8f2b733b7c9f1fc/e/aaaafbfae64372fbb245025a
    Thank you so much!
    No, the 2 profiles are not the same. The part shall be a clothes hanger. I wanted to strenghten the lower part with a bigger cone and make a veeerrrry smooth transition to the upper part with a very small cone. The crazy thing is, I was on the right track all the time.
    But, if I make the upper profile / cone smaller, it leads to a self intersecting body.
    I dont really understand why that happends, or what exactly that means. Would anybody explain that to me?
    @heiko_augustin
    Needed another profile and guide to improve the inside corner. Still not perfect but better. There is some bulging in the upper section. You may need to figure out another profile for the lower end of the upper profile.
    Hello,
    i still need to learn.
    With the new information and learning i started over:
    Garderobenhalter neu | Halter schlanker (onshape.com)
    I still cant get it to work.
    As i am confident to use all the learning, i pieced the guides to the profile, i thougt about the order, i made the selections for the guides brave.
    Right now, i get the error "cant loft with the given information.
    Would anybody please look into it, i am pretty sure i did exact the same then in the example above.
    But i cant figure out, what i am missing or doing wrong.
    Thanks
  • S1monS1mon Member Posts: 4,034 PRO
    Sketch 7 needed to have two tangent constraints between the arc and the straight lines - then it works.
    Ah yes!
    Thats nice, I finally got the full controll over my loft.
    Obviously i still got a lot to learn.
    @S1mon Of course my sketch was not fully contrained, what should always be, i know.
    Still, i want to understand what the problem was. I mean, it was not too much away from a tangent. Why was Onshape unable to use the guide? What is the problem, so i can avoid these situations in my future designs?
    Thank you
    Loft is intended to create a continuous surface. It's also required to go through the guides within a very tight tolerance. When the guides are not at least G1 (tangent) continuous, it's impossible for it to do what it's supposed to do. You probably could have created a fill surface with the sample option for guides.
