Using the Comments API
Hi all,
I've been working with Onshape's API to retrieve comments from parts within a document via the GET /comments endpoint. This seems to work fine for the original comments that were added to the part, but it does not return any of the replies to those comments. The original comments themselves have a replyCount field showing the correct number of replies, but there are no comment Ids (cid) listed in the JSON response that would allow retrieval of those comments via the GET /comment endpoint.
Has anyone had experience with the Comments API and seen this issue? The Glassworks API docs specifies that when calling GET /comments the paramater "objectType" should be set to 6, but it doesn't specify what objectType is or why it should be set to this value. Any help on this would be appreciated.
Cheers
Chris LL
Cheers
Chris LL
