Two questions
bilal_mohammadbilal_mohammad Member Posts: 4
this is the file we are talking about
Tuff Sucker Attachment | Tuff Sucker Attachment (onshape.com)
1- why can I not edit Sketch 6 and Sketch 4? (they don't become blue when I right-click and pick edit in the left bar) it looks like i can edit Sketch 2 just fine. how do I edit those two sketches?
2- I understand that on a loft the number of vertices between two surfaces needs to be the same for the loft to construct properly, however, I for the life of me cannot get the vertices to align for loft 1 and i am getting this twisted loft, is there a better way of doing this? i just want a smooth transition between the two surfaces.
  • S1monS1mon Member Posts: 3,985 PRO
    1. Sketch 6 has "fix" constraints on the curves. If you removed those you'll be able to edit it. Sketch 4 can be edited just fine, but you need to modify the numbers. It's fully constrained, but editable.
    2. Sketch 6 has two segments. Sketch 4 has 4. If you split the top and bottom segments of Sketch 4 in half, the loft will behave better.
  • bilal_mohammadbilal_mohammad Member Posts: 4
    Thanks S1mon, you are a life saver! that helped me out big time. much appreciated!
