Editing Constraints on iOS
BluchipBluchip Member Posts: 20 ✭✭
Pretty much what the subject line refers to…
How do you edit a constraint while sketching using iOS?
I have an iPad Pro and I have a tangent constraint I wish to delete. Onshape help state you can edit constraints in iOS. But I haven’t been successful at it. Understand how with browser version and PC. But the mobile version has fooled me!
I have included a screen grab that shows I have the desired tangent highlighted but cannot seem to figure how to delete it.
Thanks!
  • BluchipBluchip Member Posts: 20 ✭✭
    Ran across this annoying issue again. Created a rather complicated sketch and then tried to edit one dimension. Unbeknownst to me, the original sketch had snapped to the midpoint of a line of an underlying sketch. This midpoint constraint prevented any editing of the dimension as it was constrained.
    With a web browser versions you simply select that midpoint constraint and delete it and life goes on. But in IOS on a iPad, I do not see anyway to remove a constraint.
    Certainly, others have had this issue…no?
    Thanks folks for any thoughts on the matter!
  • john_lopez363john_lopez363 Member Posts: 140 ✭✭✭
    edited May 2024
    @Bluchip
    Select constraint... Swipe Left!
    Brilliant!!!
    john_lopez363 that’s the ticket. I tried selecting, two finger tap, etc etc. That’s a little different from other deleting processes but that will do! Should have tried that as it is so common with other IOS operations.
    Thank you so much!
