Connecting two faces along a curve
william_turleywilliam_turley Member Posts: 9
Hello. I'm trying to find the best way to connect these two faces along the curve while maintaining their height.
Any help is appreciated.
  • glen_dewsburyglen_dewsbury Member Posts: 1,253 PRO
    Public share if you can and post the link to the document. It will get a faster response to your question.
    If the two faces are equal a revolve will likely o the trick.
  • william_turleywilliam_turley Member Posts: 9
    Revolve worked perfectly! Thank you!
