variable studio improvements
david_lang457
Member Posts: 104 ✭✭✭
in General
Is there a way to import into a variable studio (from a csv or similar)?
It would also be nice if it was possible to create a table. I'm doing work where I am using different steppers and while I can create variables like:
NEMA11_width
NEMA11_bolt_spacing
NEMA11_nose_dia
NEMA11_bolt_dia
and then similar for NEMA14, 17, 23, 34, 42 it would be much nicer if I could reference a table
something like #stepper(17,width)
and even better if I could make a configuration table directly from the variable studio table
being able to reference a configuration table in a variable studio could be useful, but I'm thinking that it may end up being similar to an assembly where different parts in the assembly may have different config values
NEMA11_width
NEMA11_bolt_spacing
NEMA11_nose_dia
NEMA11_bolt_dia
#bolt(#stepper(11,bolt_dia), socket cap, head_height) to lookup the head height for a socket cap bolt of the size required for a nema11 stepper
