How can I change the BOM behavior of an assembly through the API?
Michael_Ursuliak
Member Posts: 14 ✭
I have a lot of drawings from my top assembly, I am kind of new to this API thing.
I would like to get a list of assemblies from the top assembly, use that list to go to the respective studios,
and then change the BOM behavior to Components only.
Is there a way that i can do this with the API?
I took a look through glassworks but i admit that i don't understand much of it.
You can get the current assembly using the endpoint
/assemblies/d/{did}/{wvm}/{wvmid}/e/{eid}
In the assembly definition, the field "subassemblies" gives a list of each subassembly.
Each subassembly has a documentId, documentVersion, and elementId.
These three fields will locate the assembly studio of each subassembly.
You can then use the endpoint
/metadata/d/{did}/wvm}/{wvmid}/e/{eid}
to update the metadata property for subassembly bom behaviour.
With a body similar to (replace href with your document href):{"items":[{"properties":[{"value":"2","propertyId":"57f3fb8efa3416c06701d633"}]}]}
Luckily, this field is editable in versions, so you can update the field without having to find the workspace and create a new version.
The values are 0,1,2, where 0 is assembly and components, 1 is assembly, 2 is components.0
