mid-plane mate
andre_brown101
Member Posts: 8 ✭
in General
Hi
I have 2 parts in a subassembly. they are symmetrically arranged and offset from the origin (forming a center plane) - I have placed a mate connector at its origin. the parts are cylindrical in general form.
the 2 part subassembly is inserted into a top level assembly, and the cylindrical form of one part is mated to a housing part in the top level assembly via a cylindrical mate between the faces of the parts. this works fine.
I need to mate the center plane (the mid point between the two cylindrical parts) to the origin mate connector in the top level assembly to position the subassmbly left-right. however when I do a planar mate it constrains the wrong pair of axis (xy instead of xz) and then proceeds to break the cylindrical mate.
I am going crazy. why can't I just mate planes in an assembly environment? or at very least why can't I chose which pair of axis to use for the planar mate using mate connectors?
Here's some discussion on editing mate connector within mates (using pin-slot as an example but applies to all mate types):
