API | Enumerate Revisions
Hi all -
I am starting to delve into the API development
portal and the glasswork API explorer.
Concentrating on the "Enumerate all revisions
created in a company" (https://cad.onshape.com/glassworks/explorer/#/Revision/enumerateRevisions) the API call limit is limited to 100 records. Our
company enterprise has more than 100 parts/assemblies/drawings with a revision.
Is there a way to pull all the records from the
enterprise? Not limiting it to 100?
We typically use Excel PowerQuery to report on and
manipulate data from all manner of places (SQL databases, web, spreadsheets
etc) so it would be advantageous to undertake a similar process with "Enumerate
all revisions created in a company" to have a live report of all released
parts/assemblies/drawings in our company enterprise.
Any help/guidance would be greatly appreciated.
TIA
Its generally bad practice to have an endpoint that could potentially return an enormous result. A company with enough revisions will have the endpoint timeout, or have users requesting way more data than they need.
While the api call is limited to 100, you can still get all of the records. It just requires doing multiple calls. If you look at the example response, there is a field "next" and "previous". The "next" field will provide a URL formatted for the next 100 entries. All you need to do is continually call the "next" url, add the results to the previous results, and wait for the "next" url to be null.0
While the api call is limited to 100, you can still get all of the records. It just requires doing multiple calls. If you look at the example response, there is a field "next" and "previous". The "next" field will provide a URL formatted for the next 100 entries. All you need to do is continually call the "next" url, add the results to the previous results, and wait for the "next" url to be null.0 -
https://github.com/onshape-public/onshape-ts-client#readme
has a sample that shows how to use this api to create a spreadsheet of all revisions created in your company0 -
@caden_armstrong - thanks for the reply. In principle, I understand. My API call request knowledge is beginner at best.
Using the https://cad.onshape.com/glassworks/explorer/#/Revision/enumerateRevisions complier by adding our enterprise ID I can create a URL for the request, obviously limited to max 100 results. I am then using this "Request URL" within PowerQuery to return the "live" results into Excel. The intent would then be to compare this information to our sales/purchasing SQL database to ensure that revisions are at parity and to identify any irregularities.Question: Can I build the “next” request into the “Request URL” or am I going to have to API call via a different means in Excel’s PowerQuery?
