Disobeying dimension
robert_scott_jr_robert_scott_jr_ Member Posts: 729 ✭✭✭
Hello all. I'm in the process of learning to utilize variables and configuration tables. My project is a cable gland based on cable diameter. I've come across a glitch I need to solve before I can move on. Up to this point values of the part (body) follow the configuration selected (which is 7mm) except for the dimension from the centerline to a vertical line in the sketch 'compression rib'. The value assigned is (#I_D/2)+.5mm which should be 4mm but the resulting value is 3mm. I have the suspicion that the order of my build is wrong. I've spent too much time going over this suppressing features, deleting constraints , etc. to discover my error with no success so I've come here to seek help as to where that error is; I'd appreciate a bit. - Scotty
