Removing material from extruded wall
matt_tuveson
Member Posts: 2 ✭
Hello Community -
New to using Onshape and had a quick question. I'm working
on https://cad.onshape.com/documents/998521645874f950fdbeb865/w/01994f4cfce6446f34c48375/e/b7d391cef7839d06d9320e66 and I need to create a small hole or rectangle like cut out that removes a portion of the inside walls making them open to the outside ones. This is for a 3D print. I tried making another sketch with the right view selected, but when drawing the second sketch, it ended up shifting away from the wall. Below is a screenshot of my project, and a markup of what I am trying to accomplish. Is there any easy trick to accomplish this?
Thanks,
Matt
Thanks,
Matt
Looking at your document it appears you've got it figured out. Perhaps I'm missing your intent. - Scotty
