How to extrude sketch entity instead of whole sketch in FeatureScript?
Hi, I am new to FeatureScript and wonder how to extrude only the sketch entity instead of the whole sketch.
For example, here I would like to extrude "rectangle1" with some height eg. 2 inches, and "rectangle2" with eg. 10 inches.
I thought I could create two newSketchOnPlane() and extrude them easily but it seems inappropriate way to archive this.
I would love to know what is in this case good and bad practice.
Also, can I archive the extrude of only the shape that comes from the intersection of some sketch entities?
var worldCoordSys is CoordSystem = coordSystem(vector(0, 0, 0) * meter, vector(1, 0, 0), vector(0, 0, 1));
var bucketSketch = newSketchOnPlane(context, id + "sketch1", {
"sketchPlane" : plane(worldCoordSys)
skRectangle(bucketSketch, "rectangle1", {
"firstCorner" : vector(0, 0) * meter,
"secondCorner" : vector(definition.bucket_size, definition.bucket_size)
skRectangle(bucketSketch, "rectangle2", {
"firstCorner" : vector(definition.wall_thickness, definition.wall_thickness),
"secondCorner" : vector(definition.bucket_size - definition.wall_thickness, definition.bucket_size - definition.wall_thickness)
skSolve(bucketSketch);
//insert this code after your skSolve(bucketSketch) //if you want to extrude surfaces, then use this var largestRegion = sketchEntityQuery(id + "sketch1", EntityType.EDGE, "rectangle1"); var smallest = sketchEntityQuery(id + "sketch1", EntityType.EDGE, "rectangle2"); //if solid bodies then use this var regions = qSketchRegion(id + "sketch1", false) ; var largestRegion = makeRobustQuery(context, qLargest(regions));//this will stop evaluating the areas of the regions in queries after. var smallest = qSubtraction(regions, largestRegion); //now you can extrude them opExtrude(context, id+"extrudeLargest", { "entities" : largestRegion, "direction" : evOwnerSketchPlane(context, {"entity" : largestRegion}).normal, "endBound" : BoundingType.BLIND, "endDepth" : 2 * inch }); opExtrude(context, id+"extrudeSmallest", { "entities" : smallest, "direction" : evOwnerSketchPlane(context, {"entity" : smallest}).normal, "endBound" : BoundingType.BLIND, "endDepth" : 10 * inch });
Give that a try.2
