Problems extruding rectangle with circles on end causing extrusion failure
in Drawings
Hello,
I am new to onshape and new to cad software. But I am building some parts for my sxs but I am having a problem when I take a rectangle and then add a circle at both ends. I then try and extrude it after adding thickness to the object it it is always saying that the extrusion failed to extrude selections check input. Any help would be greatly appreciated as I am learning your software.
1
Please share a link to your document so people can have a look to help you.
Sounds like your issue might be some zero thickness geometry. Check out these two links for more info:https://forum.onshape.com/discussion/comment/88187#Comment_88187
https://forum.onshape.com/discussion/20585/better-error-handling-and-training-around-zero-thickness-parasolid-limits
