Tapered internal spline
in Drawings
Hello all, fairly new to Onshape and trying to draw a tapered internal spline inside a tapered gear. I have managed to draw it but something is wrong with it. Wondering if you could point me in the right direction. tia please.https://cad.onshape.com/documents/3c05a3022144043090be4478/w/c32a8d86f19ea4899399dc94/e/a9b11b2e7ec6e2c70995cc35
I found some interesting things in your sketches and methods. There are a lack of constraints in the sketches and misalignment of centers. I'm wondering why surfaces are being used then filled to close for solids when an extrude solid will do nicely? I put together some thoughts in my sample as to methods that will save some time. The tooth profile, you will have to verify. I did not. Hope this sample helps you get a better start.
https://cad.onshape.com/documents/873d662318690a93216c5bc3/w/4c92738c77fe5070ba4b78fe/e/0f93ac440724ac62c1d73558
You might want to look into this feature script for generating gears.
https://cad.onshape.com/documents/5742c8cde4b06c68b362d748/w/b493e0cb681bbf9497d9f4b3/e/c72760543a0d4412e72f6d38
https://cad.onshape.com/documents/db73276df7574c7e29b36a0a/w/677116fcd7a1ac2e1fe6dcb3/e/9cdd845cb072bf9378d4151d
