If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
How to set up Onshape to work with french accents
 jerome_magnien
                    Member Posts: 2 EDU
jerome_magnien
                    Member Posts: 2 EDU
                    How to set up Onshape to work with french accents when I import an assembly. My second question is how to import an assembly with sub assembly inside ?
Thank you
                Thank you
https://cad.onshape.com/help/Content/Plans/preferences.htm?Highlight=Language
I assume you mean when importing a file to Onshape that has special characters in it. Like &!äöü_:; or similar characters.
A general recommendation is to not use special characters in file names - they can always cause issues, also with Importing to Onshape.
To your second question: If the .zip file you import has the same name than the top level assembly, Onshape will recognise the assembly structure.
More detailed Documentation on how to import here:
https://cad.onshape.com/help/Content/uploadfiles.htm#importing-files-desktop
