Following a curved path in an assembly
outstandingoutstanding Member Posts: 56 ✭✭
If I want the vehicle to follow the curved rail (blue), what kind of joints can I use?
I have tried using my imagination but cannot see, how this can be made to move in Onshape.
In other tools, I can imagine creating a mate between the wheels that then "slides" along the curved path. I will likely make a revolute joint since the curved section is a circular arc. How would you approach this?
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 118
    Hey @asko_kauppi,
    Could you share a link to your (public) document so people can have a look?
    Should probably be feasible with a couple of tangent mates. Thanks
  • outstandingoutstanding Member Posts: 56 ✭✭
    edited October 2023
    Of course! V18, then open "Vehicle Rolling A":
    I added a tangent mate between the front wheel and the curved main rail, in V19.
    This is the first time I'm using a tangent mate. Did read the documentation, but here it's clearly not doing what I would expect.
    Expected:
    - wheel surface follows the curved rail
    Actual:
    - there is some constraint, but the selected faces don't touch
    I still made one - simplified - model of the situation.
    https://cad.onshape.com/documents/02c303679e6677195f7b884e/v/54498b3cede9361366cb7557/e/7e1781847d155c549f526939
    1. If I choose a face for the Tangent Mate, it acts weird
    2. If I instead choose an edge, things remain more tidy
    What I did to create such a mid-edge is make a slight draft to the extrusion of that wheel. This will likely get me further with my model, but clearly work could be done to improve the Tangent Mate.
