help..... sweeping along a helix not working with more complex models
in my document here, I try to make the sweep 5 work on a project I am doing.....
but, whenever I try to add a channel in from the center to the helix hole in the body, it will not work.... If I follow a straight path and not the helix, no problem
did I do something wrong? a way to fix it? please help
https://cad.onshape.com/documents/522e4ba9f75c3d2af1b3ffc1/w/413d33f81e127e001a72173e/e/c4d2fd251bbc4c8c1b12a9b4
thank you! would not have figured it out without your help!
