Applying an appearance to entire part body rather than surface only...
Stormi_Backus
Member Posts: 49 ✭
I'm surprised I couldn't find anyone else on the forum having this issue but here we go...
How can I change the color of my entire part body rather than just the part's surface when applying an appearance?
I have a logo extrusion that appears as OnShape's default blue rather than the grey appearance I have applied. (See screenshot below). If this is something that can be done programmatically using FS, that would be nice - this is an FS generated part anyway.
Thanks in advance!
Thanks in advance!
MichaelPascoe
Member Posts: 2,818 PRO
You could set the appearance in either. Since your logo feature isn't referencing the part, it would be extra clicks if you put it there. Add this to line 554 of the gear feature and that will set it's color.
https://cad.onshape.com/documents/97df39c5762995b372a45f6b/w/74fd179228f3f388ca4bf66a...setProperty(context, { "entities" : qCreatedBy(id + "APlateExtrusion", EntityType.BODY), "propertyType" : PropertyType.APPEARANCE, "value" : color(.3, .3, .3) });
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________0
@Stormi_Backus each of these things you mentioned are possible. Please share a link to your document so we can take a closer look.
Perhaps your custom feature is extruding separate parts instead of merging the logo with the main part? It's hard to tell without the context of a document.
If you share a link to your custom feature we can help you with that too. SetProperty() is how you can change the appearance of parts created within FeatureScript.
RENDERCAD
https://cad.onshape.com/documents/51d4a2a74f19d96e738a7a86/w/0cffaf06f18f5433f9dce56d/e/4122ee75c726579bc9fffe0c?renderMode=0&uiState=652d781765fd8f1209449453
Here is the link to the logo FS: https://cad.onshape.com/documents/1c864a0f76cc68fc6a77ba31/w/dff5ee744601abbaacb0232f/e/a1bef027f56bc0bbd87e274b?renderMode=0&uiState=652d79836813a23d236d82f8
setProperty(context, { "entities" : qCreatedBy(id + "APlateExtrusion", EntityType.BODY), "propertyType" : PropertyType.APPEARANCE, "value" : color(.3, .3, .3) });RENDERCAD
