Flat pattern not visable
dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
Is this a bug, I can,t see the flat pattern,s anymore, tried everything, any tips?
  • _anton_anton Member, Onshape Employees Posts: 510 image
    I don't see the view cube in the sheet metal panel. Could be a rendering bug. Do you see any errors in the browser console (Option + ⌘ + J (on macOS), or Shift + CTRL + J)?
    If this is a persistent problem, I'd recommend contacting support.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Ctrl plus R did the job, thanks
