How can I rotate a part and sweep the rotation path?
Hi all - Having trouble figuring this out. How can I rotate a part and sweep the rotation path?
Imagine I'm making a keyhole on the surface of a square block.  Once the key passes through the key hole, it turns 90 degrees.  How can I rotate that keyhole sketch/extrusion inside the block and include the rotation path into the extrusion to be cut out of the block?  This is a very simplified version of what I'm trying to attempt.
Thank you!
