Does Onshape have the Equivilent of "Press-Pull in Fusion 360?"
I only wanted to see if I could pull a triangle part way up a face. but could not find the tool to do it. I ended up doing about 5 extrusions as there was many facets of the 3d. Please go easy on me
I do not use onshape everyday... use Revit mostly instead. hard getting used to note being able align lines and shapes with 2 key strokes and a click of the mouse. still not worked out how to do that in Onshape.
https://cad.onshape.com/help/Content/moveface.htm#:~:text=To%20move%20a%20face%2C%20select,distance%20to%20offset%20or%20translate.
