Changing sketch and updating assemblies
paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
I am trying to change the Sketch 1 dimension 31.5 deg to different degrees between 30 and 32 deg to see what works best for my final assembly. The Sub assembly and full assembly do not seem to update so I have to redo them every time. Am I missing something or doing something wrong?   https://cad.onshape.com/documents/bd3bdac792bd09f8ef7bb525/w/032186bb3776d7d38ae874f6/e/fd30a5678700adc1b087b76e
  • glen_dewsburyglen_dewsbury Member Posts: 1,253 PRO
    edited October 2023
    @paul_bartlett
    One of the simpler ways to accomplish what you're looking for is to make a variable studio. The piece of ribbon is based on variables. You can open the variable table for editing in the part studio and assembly. You'll want to figure out how to calculate the variables in the table to make all fit or you may be there longer trying to get close. Try changing table variables while in the assy and watch what happens. It may help to be able to visualize what the calculation need to be.
    A side note, check your mates in the original assembly. They look crooked. You'll see I added mate connecters on the ribbon piece and made sure the axis' were aligned to suit edges of the part. Requires less zooming to find the faces in assy.
    https://cad.onshape.com/documents/c69d76d2e1a0569f524cb8f6/w/0ecf92975e948473e6102a37/e/f7a7e0e2b16d16edda3ddbe7
    Hope this helps.
  • paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
    Thank You Glen this is exactly what I wanted. I added 2 more pieces and to the ribbon and all works very good. I would like to some how be able to center the complete assembly on the Center point to locate the sphere that will be going in the assembly. Not really necessary as I will do it when I build the assembly in the shop. File to Fit,  Fit to function,
    https://cad.onshape.com/documents/9e3aa08c3a81094e04655bb9/w/c7595b120fd1cc04231cd04e/e/45beffed145210b26c307da2
    If you show the sphere in part studio you can build directly from it for your ribbons.
