Spline to follow a curve
david_mrozinskidavid_mrozinski Member Posts: 7
I am trying to create a spline that will be a rail for a loft. I need the rail to replicate a projected curve. I have been trying to add point by point, but I’m finding that even though I snapped to the projected curve while tracing, it’s not coincident with the projected curve when I examine closely. Close but not exact.
Any suggestions
  • Jon_HJon_H Member Posts: 37 PRO
    edited October 2023
    I would first enable high quality in the render option (left side of the screen, drop down under the view cube). Might be just a renderer issue.
    Then, maybe using "3D fit spline" (Edges, not Vertices) could help creating a precise guide.
  • S1monS1mon Member Posts: 3,948 PRO
    Fit spline through a lot of points is likely to produce a lumpy curve.
    Can you share a public document or at least an image of the curve in question? There are some good techniques depending on the shape of your intended curve.
  • david_mrozinskidavid_mrozinski Member Posts: 7
    Thank you. That suggestion helped.
