How Can I Make Surfaces Solids to Add to the Part? (No, it's not as simple as Fill or Enclose)
Hottestsauce
Member Posts: 6 EDU
Hello everyone! I was working on a design for a pen as my first CAD project. I made the bore, and metal clip, but when I began on the end cap, I hit a problem. . . In order to make the cone on the end, I decided to try to loft from the big cylinder to a smaller ring, making a hollow cone with a hole for the nib. However, after messing around with the loft tool, all I got was an error stating "Cannot use faces or regions with inner loops as profiles." After that I tried lofting the inside and outside edges individually, and that worked alright, but I was left with two surfaces and no way to make them solid. I've tried the fill tool, encolose, and I can't figure out how to make it solid!!! It's also annoying, because in the assembly, the tip inserts without the end cone. Any help is much appreciated! Pics included, and here is the link to the design:
https://cad.onshape.com/documents/52ce21b1c3711761bb09d215/w/0f394c8a603e3337b1e67d69/e/938e084e23bf97e733576453?renderMode=0&uiState=653d70dae659ee01998e9b3c
If you need any more info, just let me know!
robert_scott_jr_
Member Posts: 854 ✭✭✭
Hello. Using the Thicken tool on the outer surface worked but attempting to add the feature to the existing pen body vs. creating a new part would not work until I fixed the 'threading shape' sketch to ensure that the vertical flat of the triangle truly intersected with the inside wall of the pen body. By the way, in the process of making this work I did go ahead and created a new part (cone) but then trying to boolean the cone and pen body together failed due to the bad thread. - Scotty0
V
V
