How can I make this typical U shaped "trough" into V shaped trough?
price_cobb
Member Posts: 38 ✭
in Drawings
Hello.
I'm in the process of drawing up a part that is not longer made for a friend of mine and have run out of ideas. Truth is, I'm pretty sure that this trough (or groove) needs to be replicated to mimic the part 100% but then I don't know that so might as well make the part just exactly like the part handed to me.
I've run out of ideas and openly admit my getting stuck is sometimes lack of imagination and sometimes simply that I don't know how to apply a tool in OnShape to reach the desired result.
The picture on the left is looking down on on the part with the red arrows pointing to the trough as it is a the moment. Note that the trough is on three sides only. Look closely and you can see that the bottom is without trough.
Looking at the sectioned picture on the right, you can see the trough laying at the bottom of the green arrow and red lines. If you look at the red lines, they are laid back to indicate how I'd like this side of the trough to be formed. Doing so eliminates the brown are the green arrow points too.
If the pictures don't show well enough what I'm trying to do please let me know. I've shared this for Onshape folk to see as well as include the link here.
https://cad.onshape.com/documents/f615f2579c8da1ae32e8ba53/w/c36488fc309618e00b9b106e/e/9a7b517d91b0511452f1e65b
Thanks everyone for helping.
robert_scott_jr_
Member Posts: 737 ✭✭✭
Hello. I tried a .02" chamfer that seems to work nicely. Is that the result you are looking for? There are other options within the chamfer dialog that may work better for your desired outcome.- Scotty0
