drawing a line with Features Script
hervé_pipon
Member Posts: 60 ✭✭
Hello I want to draw a sphere and its radius.
I wrote this code:
The FeatureScript Notice shows :
for the line
I don't know why ??
Can somebody explain me ?
I also saw that sphereCenter has unit { "meter" : 2 } , but sphereRadius has unit { "meter" : 1 } ??
I don't understand
https://cad.onshape.com/documents/b5eb7563c9f8d34013c45353/w/a8328a22ba0852fc6de829ba/e/3946d40111b0b87308a02466
I wrote this code:
annotation { "Feature Type Name" : "drawSphere" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
annotation { "Name" : "Radius" }
isLength(definition.Radius, NONNEGATIVE_LENGTH_BOUNDS);
annotation { "X" : "X coord" }
isLength(definition.Xcoord, LENGTH_BOUNDS);
annotation { "Y" : "X coord" }
isLength(definition.Ycoord, LENGTH_BOUNDS);
annotation { "Z" : "Z coord" }
isLength(definition.Zcoord, LENGTH_BOUNDS);
println("start");
var R = definition.Radius;
var x0 = definition.Xcoord;
var y0 = definition.Ycoord;
var z0 = definition.Zcoord;
println("R = " ~ R);
println("x0 = " ~ x0);
// Créez une esquisse 2D sur un plan de votre choix
var sketch = newSketch(context, id + "sketch", {
"sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
const sphereCenter = vector(x0, y0, z0) * meter; // Centre de la sphère
const sphereRadius = vector(R.value, 0 , 0 ) * meter ;
println("sphereCenter = " ~ sphereCenter);
println("sphereRadius = " ~ sphereRadius);
// Ajoutez une ligne à l'esquisse
const startPoint = sphereCenter ; // Point de départ de la ligne Can not add ValueWithUnits (map) and number
const endPoint = sphereCenter + sphereRadius; // Point d'arrêt de la ligne
skLineSegment(sketch, "myLine", {
"start" : startPoint,
"end" : endPoint
opSphere(context, id, {
"radius" : R,
"center" : vector(definition.Xcoord, definition.Ycoord, definition.Zcoord)
});The FeatureScript Notice shows :
start
R = ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.1 }
x0 = ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 }
sphereCenter = Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : 2 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 2 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 2 } , "value" : 0 } ]
sphereRadius = Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0.1 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } ]
Result: Regeneration completewith an error :
Precondition of operator+ failed (lhs.unit == rhs.unit) | |||
for the line
I don't know why ??
I don't understand
This is multiplying a vector of three lengths by another length. Remove the "* meter".1 -
just use opFitSpline with 2 3d points. it is the fastest at creating a line.2
@Jacob_Corder Thank you, that is really easier
opFitSpline(context, id + "line_1" , { "points" : [ startPoint, endPoint ] });
@_anton Thank you, I understand why there is { "meter" : 2 } on SphereCenterHowever I got another error ( I use my own LineSegment function to see the error ...)
const startPoint = sphereCenter ; const endPoint = sphereCenter + sphereRadius; println("A = " ~ (startPoint is undefined) ~ " " ~ startPoint ); println("B = " ~ is2dPoint(startPoint)); LineSegment(sketch, "myLine", { "start" : startPoint, "end" : endPoint });export function LineSegment(sketch is Sketch, lineId is string, value is map) precondition { value.start is undefined ; <<<< ERROR is2dPoint(value.start); value.end is undefined || is2dPoint(value.end); value.construction is undefined || value.construction is boolean; } { return @skLineSegment(sketch, lineId, value); }The printout isA = false Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : 1 } , "value" : 0 } ]B = falseBut I got the error Precondition of LineSegment failed (value.start is undefined) on line value.start is undefined ;Do you know why , as println("A = " ~ (startPoint is undefined)) prints false ?0 -
The "is" keyword is reserved for typechecks, so it's actually checking to see if startPoint passes a typecheck on type "undefined." You want to use the equality/inequality operators instead when checking inside of the precondition and for the println() checks.
Ignore that (explained in comment below)export function LineSegment(sketch is Sketch, lineId is string, value is map) precondition { value.start != undefined; is2dPoint(value.start); value.end is undefined || is2dPoint(value.end); value.construction is undefined || value.construction is boolean; } { return @skLineSegment(sketch, lineId, value); }
Your 2D point check will still fail though. So you will want to make sure you are creating a 2D vector instead of a 3D one. Since you are using the top plane, you can just remove the Z inputs from your points and it shouldn't throw any more errors for you.
Also don't forget to solve your sketch when you're done, otherwise you won't see the line that you just programmed.LineSegment(sketch, "myLine", { "start" : startPoint, "end" : endPoint }); skSolve(sketch);
chadstoltzfus@premiercb.com1 -
@chadstoltzfus Thank you, I forgot that we are working on 2D vector instead of a 3D on sketch , It works when I remove z axis !
Concerning value.start != undefined; and value.start is undefined ; I don't really understand the use :
In the skLineSegment the check is on value.start is undefined || is2dPoint(value.start); what's the use ?0 -
Oh that's my bad you're right, "value.start == undefined" and "value.start is undefined" should return the same thing.
So the precondition is checking to make sure all boolean statements evaluate to true in order to execute the next block of code. So in skLineSegment the line isvalue.start is undefined || is2dPoint(value.start);This is checking to make sure value.start is a defined value and that it is also a 2D point. And since is2DPoint evaluates to true the precondition does not fail.
However, if you separate them out,value.start is undefined;will evaluate to false (since value.start is defined). So that will cause the precondition to fail.
I'm assuming that Onshape's function is checking if the field is undefined so that way the error is thrown by skLineSegment instead of in is2dPoint, as sending an undefined argument to is2dPoint would have the error thrown in that function and maybe return a more ambiguous error.Applications Developer at Premier Custom Built
@chadstoltzfus Thanks a lot, it's clearer, I understand my mistake; I wanted to separate the two clauses, to find out which one was in problem, but in fact I created a new error.0
