Difficulties inserting countersunk standard bolts
martin_kopplow
Member Posts: 1,147 PRO
I'm trying to insert standard content countersunk bolts into a countersunk bore. It appears the common reference point for both is the point of the cone of the countersunk face. Fine. While it is quite easy to grab the bolt by the mate connector located at the respective point, snapping it onto the point representing the bore reference appears close to impossible: That one lies outside the face, and even though it diplays fine while I hover over the counterbore face, it diappears as soon as I move towards it, that is into the hole, as this move forces me to stop hovering over the face.
I found nothing detailed about the procedure in the documentation.
What secret trick am I missing?
