sloped surface creation between two surfaces on a part
michial_andersonmichial_anderson Member Posts: 5 EDU
Hi I am designing this and I need an angled surface from the outer circle diameter to the inner circle between the blades. The point is for it to pick up marbles and then funnel them to the middle diameter of the inner circle and onto a different ramp. Please help me with how I might be able to achieve that. Thank you.
https://cad.onshape.com/documents/dd66f7857c392d05c7469af5/w/5bf9d2f4d43e6544f4031795/e/1794a0d39de1523a90a7b3f3?renderMode=0&uiState=654bf60ba65dfb476e29c4c2
  • robert_scott_jr_robert_scott_jr_ Member Posts: 761 ✭✭✭
    Hello Michael. I took a look at your document but could not grasp the intent you described. Did you already accomplish it with Chamfer 1? - Scotty
