Updating Variables through Python API
alex_kagayalex_kagay Member Posts: 2
Hi,
I have started a project where I would like to do a GET to get the variables of a part, do a mathematical operation, and then POST the updated variables. I have gotten the GET and the mathematical operation, and am struggling to actually POST. My document is linked here.
I have obtained the url from the Glassworks API Explorer, but I am not sure what to use for the Request body or how to pass that into the POST statement.
When I use just the Glassworks API explorer, I get an error 404, not found.
My code for posting is:
        fixed_url = '/api/v6/variables/d/did/w/wid/e/eid/variables'
        fixed_url = self.fix_url(fixed_url,self.element.did,self.element.wvmid,self.element.eid,999)
        params = {}
        headers = {'Accept': 'application/vnd.onshape.v1+json; charset=UTF-8;qs=0.1', 'Content-Type': 'application/json'}
        vars = json.loads(response.content)
        value1 = "1.5 meter"
        vars[0]["variables"][0]["value"] = value1
        payload = {"content":vars}
        response = requests.post(self.base+fixed_url,
                           params=params,
                           auth=self.api_keys,
                           headers=headers,
                           payload=payload)
I would appreciate any insight to what I am doing wrong, thank you!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    I think using POST with the variables endpoint only works with Variable Studios.
    To update variable features, I think you need to use the features endpoint.
    https://cad.onshape.com/api/partstudios/d/{DID}/w/{WID}/e/{EID}/features/featureid/{FID}
  • philip_kristoffersenphilip_kristoffersen Member Posts: 5
    I have the exact same problem both when variables are in variables studio and not
    this worked for me:
    import requests
    # Get all of the variables in the Part Studio
    response = requests.get(
        "https://cad.onshape.com/api/variables/d/{}/{}/{}/e/{}/variables".format(
            DID, WVM, WID, EID
        auth=(API_ACCESS, API_SECRET),
        headers={
            "Accept": "application/json;charset=UTF-8; qs=0.09",
            "Content-Type": "application/json"
    response = response.json()
    # Grab just the variables from the response
    variables = response[0]["variables"]
    # Update the angles, adding 5 degrees
    for var in variables:
      if var['type'] == "ANGLE":
              arr = var['expression'].split(" ")
              arr[0] = int(arr[0]) + 5
              var['expression'] = str(arr[0]) + " deg"
              print("Angle updated to " + var['expression'])
    payload = response[0]["variables"]
    # Post the variables back
        "https://cad.onshape.com/api/variables/d/{}/w/{}/e/{}/variables".format(
            DID, WID, EID
        headers={
        json=payload
    # Response 204 is success with no content
    print<span>(response)</span><br><br>
